Cheers Steve for that,has put my mind at ease a bit got the car booked in on Thursday for them to check it out let you know the outcome
Navara 2021
- Timing chain slipped
Nissan Serena
New owner of a 2023 juke
Strange electrical issues
Hello From italy
car won't start
- Hello
