  2. Oh nice easy fix then - could have done quite a bit of damage to the electronics if it had come off completely. Glad to hear its fine now.
  3. not sure that you can but if you can remove the chain cover by removing the studs individually then that would be easier and also as long as the valves have not contacted the pistons then it should be okay
  4. I think possibly the same as when you take the fob apart it is a known fault on some of the fobs for the lock/unlock buttons on the fob (*which can be separate to the boot lock) become detached from the circuit board, (*depending on which fob you have). You can repair the fob with a kit from eBay and as long as you have soldering skills and a steady hand then its a very cheap job to do https://www.ebay.co.uk/sch/i.html?_nkw=2014+nissan+note+fob+repair+kit+microswitches&_sacat=0&_from=R40&_trksid=p2334524.m570.l1313&_odkw=2014+nissan+note+fob+repair+kit&_osacat=0
  5. This would be transmission drag generated by the various components in the transfer box being rotated with one or more wheels on the ground. Equally there is transmission wind-up which can be dangerous if undoing wheel nuts and the wheel is free to turn with tremendous force which can break an arm so be careful if the car has been driven around on tarmac and with sharp turning (such as driving onto a driveway).
  6. Today
  7. I would start with any serviceable items that are overdue, oil, filter, air filter, fuel filter, etc then I would also be checking for the condition of rubber vacuum and breather hoses to see if they are split or perished. This can usually be identified by a hissing noise with the engine running at idle. Replace parts if you find any damage to the hoses or gaskets around the intake system (inlet manifold, etc) Alternatively, it may be something as simple as an exhaust leak - place a rag over the rear silencer tailpipe with the engine at idle speed (outside in the fresh air to avoid carbon monoxide poisoning) and if you hear a hissing from the exhaust front section, manifold or oxygen sensor(s) then that is your fault.
  8. Reconditioned transmission would be the best way forwards or if not a secondhand used transmission from a wreckers yard as it may have been replaced before the vehicle was scrapped. Either way, ensure that it is the proper fluid going into the replacement transmission and change regularly (before it is due)
  9. I thought it may be a radar sensor for police speed cameras as they are usually mounted on top of the dashboard
  10. Always make sure the engine is maintained at regular or even before its due to ensure the oil quality remains in good order, especially when it comes to the smaller engines which can generate quite a bit of heat when working hard. Make sure it has the best quality oil you can afford.
  11. Yesterday
  12. thats where i would look again, maybe rats had a nibble before, not an easy task
  13. Last week
  14. Hi Adrian Have you tried looking for universal strips on ebay? if you find the right size I believe the join needs to be at the bottom
  15. Earlier
  16. Ciao Riki Enjoy the Xtrail my friend. Happy new year!
  17. Good day to all you Jukie owners. My Nissan Juke doesn’t seem very fuel efficient for a small car. I mainly do short trips and I’m only getting low 30s mpg. It’s a 1.2 DIG-T petrol. I was expecting better but maybe that’s just unrealistic. Is this normal for the Nissan Juke or should I be checking things like tyre pressures, air filter or spark plugs? Curious what other owners actually get day to day. Cheers Guys
  18. I am guessing it is part of the process for charging the battery but I would double check it with the dealer or Google search the symptoms and see what you can find
  19. I would say the first place to start is the battery and terminals (ensure they are clean and tight) from there i would check the battery condition to ensure it is fully charged. If its not charged then check the alternator drivebelt and see if the red Ignition lamp comes on goes off when the engine is turning
  20. Fuel efficiency (of whatever source - petrol, diesel, electric, hydrogen, etc) is quite popular on many forums at the moment. Mainly because of the fact that people bought a vehicle based on the manufacturer's advertised efficiency which has been way short of what is actually achieving in the real world. Have a check on forums such as ToyotaOwnersClub.com and there is a huge discussion which debates the best methods of driving with electric or hybrid vehicles. Good luck and Merry Christmas to you also!
  21. Hi...welcome to the Club
  22. Hello, I have a petrol 2015 (65) 1.2 DIG-T N-TEC Xtronic I’m having electrical issues. These have started over the past month. The car is used daily. Multiple times regular Back lighting of center console is off. So the main media display still works normally and is visible. But all other lighting is off including the air conditioning digital display is off and all orange lighting off behind all button controls including the auto box gearstick back lighting is off. All functionality of all buttons still works normally but lighting doesn’t. Sometimes the lights work sometimes they don’t. Sometimes when I turn ignition on they work then when I start car they turn off. Multiple times regular Sporadic engine warning light (yellow) - P0594 cruise control servo control circuit / open. This stays on for a day or so then turns off then reappears a few days later. Both of cruise control and speed limiter systems work fine as normal when this light is on. One time Power steering light (yellow) - I believe my model has electric power steering. This stayed on for a day or so then turned off I have checked the voltage over battery when switched off (12.58v) and alternator reading (14.28v) when engine on. Halfords did battery health check and confirmed battery fine at 94% health. The car mechanically runs fine. Can anyone help with what to look into next prior to me having to admit defeat and take car to auto electrician
  23. I assume its a manual transmission or automatic? A cold engine can produce these symptoms and wonder if it does it when starting the engine when hot?
  24. The CVT does sound strange when driving compared to a manual transmission. But if you can find another just to test drive and make a comparison to satisfy yourself as to whether it is normal or not.
  25. I would say it is the anti-roll bar drop links that are failing - replaced some a little while ago and they put up a fight so be prepared to spend quite a bit of time grinding them off. Also, check the coil springs are not snapped and that the dampers are not leaking
  26. I will contact the dealer and see what they say on any updates. Thanks for your help.
  27. The main thing to worry about is oil quality, levels, and period between changes. This all affects the internal engine parts and particularly timing chains. Technically, they should last if treated considerately (e.g. allowing engine to warm up before driving off when cold, avoiding stop/start journeys as best as possible, not driving at high revs initially, etc). Cars have become so reliable and long lasting since I first started driving (early 1980's) and then new cars would only last about 10 years or at least had an engine replacement in that time. Nowadays, cars last beyond 20 years quite happily as long as they are serviced and maintained properly. Mileages in excess of 100k is quite reasonable now but back then it was classes as high miles when it was at 50k or 60k.
  28. I always tend to use Castrol Oil Selector as a true guide on the specific oil to use (SAE, etc) - Grade is no so important unless you live in a very cold or hot country. https://www.castrol.com/en_gb/united-kingdom/home/product-finder.html Mostly, oil and filter are most important service items but overlooked items such as gear oils, fuel, pollen and air filters are equally important and you should find the time to get those replaced individually.
  29. Hi all, I have a bit of a strange issue with my reverse camera and wondered if anyone had experienced the same and managed a fix, Intermittently my reverse camera flickers and goes black, as if maybe a loose connection? Other times works absolutely fine, However the strange part is that every now and then when reverse is selected the camera shows a still image like a snapshot of say a previous reverse? Which is weird because obviously it doesn’t record so how would it show that? Coincidentally also when the camera does go black/flickering the front camera then also shows black. Any help appreciated, also is it easy to get to and inspect the camera if necessary? Thanks
  30. Hi @Esteban .... The Juke is one of the best cars built by Nissan (apart from the GTR) and you should have very few problems with it. Have a great Crimbo as well :-)
