  2. williams_k joined the community
  3. Today
  4. Recently, the key fob for my 2014 Nissan Note has been able to unlock all the doors except the boot. Please advise on what the possible fault might be.
  5. Need weather door strips.would anyone know where I can get some from please. It would be a shame to scrap the car, also for future knowledge is it still possible to get a window screen. Please can you help me.
  6. Yesterday
  7. RobertW joined the community
  8. I have a 2013 J10 4WD . I have jacked the front wheels up, transmission in neutral but the wheels are not spinning freely, as they should. I can feel the transmission moving as I rotate the wheel. Is there a known issue or does anyone have any idea what could be the issue? Thanks
  9. SteveG joined the community
  10. Last week
  11. marktrans joined the community
  12. 2005 Nissan Primera Engine fault appears saying PO171 Fuel System Lean fault and fuel economy has skyrocketed. 2 mechanics have said can be many things and don't want to really get involved. Anyone else had similar issues? Also key fob not working even after changing battery. Has been playing up for a while where I need to make a clicking noise when key is taken out of ignition but now is not working. Thanks in advance
  13. Hey all, new to this forum. My partner's pulsar has done 112,000 klms and the CVT is broken and rattling. We dont have the $6,000 to fix it. What other options do I have? eg 2nd hand tranny, reconditioned tranny, repair. Any other advice? Rob.
  14. Robbennettcolyton joined the community
  15. T.S joined the community
  16. Craig v joined the community
  17. Turns out the second device is part of the security system, some kind of sensor.
  18. Rider876 joined the community
  19. Earlier
  20. AlexStarRider joined the community
  21. Ciao Riki Enjoy the Xtrail my friend. Happy new year!
  22. hi The 2nd one may be ETC toll collector. Does it have a slot for a card?
  23. Hi All 2015 Nissan Serena: Any ideas on what these two are for ?
  24. Hi @Riki .... welcome to the club Enjoy your X-Trail when you get it
  25. Trevor started following Hello From italy
  26. Good day to all you Jukie owners. My Nissan Juke doesn’t seem very fuel efficient for a small car. I mainly do short trips and I’m only getting low 30s mpg. It’s a 1.2 DIG-T petrol. I was expecting better but maybe that’s just unrealistic. Is this normal for the Nissan Juke or should I be checking things like tyre pressures, air filter or spark plugs? Curious what other owners actually get day to day. Cheers Guys
  27. Riki started following Nissan X-Trail Forum
  28. Hello to everyone! I'm buying an x Trail e-power 4x4!
  29. Hi - I was checking the timing on my Pulsar 1.2 DIG-T engine and the chain has slipped while turning the crankshaft. Is there a way to fix this without removing the head?
  30. That sounds like one of the wheel sensors has gone faulty - a scan of the fault codes in the ABS system will more than likely show a code for a wheel sensor
  31. My navara has has 2 amber warning lights come on when driving, crash detecion and traction control. Just wondering if any of yous know what this could be Many thanks
  32. I am guessing it is part of the process for charging the battery but I would double check it with the dealer or Google search the symptoms and see what you can find
  33. I would say the first place to start is the battery and terminals (ensure they are clean and tight) from there i would check the battery condition to ensure it is fully charged. If its not charged then check the alternator drivebelt and see if the red Ignition lamp comes on goes off when the engine is turning
  34. Fuel efficiency (of whatever source - petrol, diesel, electric, hydrogen, etc) is quite popular on many forums at the moment. Mainly because of the fact that people bought a vehicle based on the manufacturer's advertised efficiency which has been way short of what is actually achieving in the real world. Have a check on forums such as ToyotaOwnersClub.com and there is a huge discussion which debates the best methods of driving with electric or hybrid vehicles. Good luck and Merry Christmas to you also!
  35. I’ve had my Nissan Qashqai e-Power for a few months now and I’m a bit disappointed with the fuel economy. I’m mainly doing town driving and expected better mpg based on what I read before buying. I know driving style matters but it still seems lower than it should be. Is this normal for the Nissan Qashqai e-Power or am I missing something in how it should be driven to get the best efficiency? Merry Christmas!
  36. Hi...welcome to the Club
  37. Proud new owner of a 91 Homy! Looking forward to learning and sharing
  38. Hello, I have a petrol 2015 (65) 1.2 DIG-T N-TEC Xtronic I’m having electrical issues. These have started over the past month. The car is used daily. Multiple times regular Back lighting of center console is off. So the main media display still works normally and is visible. But all other lighting is off including the air conditioning digital display is off and all orange lighting off behind all button controls including the auto box gearstick back lighting is off. All functionality of all buttons still works normally but lighting doesn’t. Sometimes the lights work sometimes they don’t. Sometimes when I turn ignition on they work then when I start car they turn off. Multiple times regular Sporadic engine warning light (yellow) - P0594 cruise control servo control circuit / open. This stays on for a day or so then turns off then reappears a few days later. Both of cruise control and speed limiter systems work fine as normal when this light is on. One time Power steering light (yellow) - I believe my model has electric power steering. This stayed on for a day or so then turned off I have checked the voltage over battery when switched off (12.58v) and alternator reading (14.28v) when engine on. Halfords did battery health check and confirmed battery fine at 94% health. The car mechanically runs fine. Can anyone help with what to look into next prior to me having to admit defeat and take car to auto electrician
  39. nissan micra 2014 the ignition lights up when i turn the key but when I turn to start it won't start. Also, as soon as I turn it on the radiator fan comes up although the engine is cold. The battery is ok. I drove the car all day, today, and after parked for a couple of hours this happened.
