Riki started following Nissan X-Trail Forum
Hello From italy
Riki joined the community
Timing chain slipped
Navara 2021
Navara 2021
Neil p joined the community
car won't start
MIKE ACK joined the community
Adrian Rothero joined the community
SPJW joined the community
- Hello
- Hello
Rbev joined the community
- car won't start
Carlos joined the community
Genus9 joined the community
