Nissan Serena
Turns out the second device is part of the security system, some kind of sensor.
Rider876 joined the community
- Nissan Serena
AlexStarRider joined the community
Hello From italy
Nissan Serena
hi The 2nd one may be ETC toll collector. Does it have a slot for a card?
spadoni joined the community
Nissan Serena
Hello From italy
Trevor started following Hello From italy
Riki started following Nissan X-Trail Forum
Hello From italy
Riki joined the community
Timing chain slipped
Navara 2021
Navara 2021
Neil p joined the community
car won't start
MIKE ACK joined the community
Adrian Rothero joined the community
SPJW joined the community
- Hello
- Hello
- car won't start
