Clare bear Posted April 28 Posted April 28 After some help. My air blower is intermittent, some tomes it works sometimes it doesn't. Fuse has been checked, not sure if a new fan is required? Do you get to it by taking the glovebox out rather than the whole dashboard?
Trevor Posted April 28 Posted April 28 I would start by removing the glovebox to see how much access you gain, if not much then continue to remove more dashboard components
Trevor Posted April 28 Posted April 28 I would start by checking the electrical connection into the motor and if it spins up when you turn everything on the there's the problem
