- P0356 error code
Hi....welcome to the Club The simplest and most effective and also the cheapest option is to but yourself a Smoke Generator which will instantly identify where the leak is coming from. https://www.ebay.co.uk/itm/315502976341?itmmeta=01KEGZPWYGJ259PS400VMKP27X&hash=item4975715d55 All you need to do is place it in the area where the leak is coming from and unlike water (which tracks to the lowest point from where it is leaking) the smoke goes directly out of the point of entry of the leak. At a cost of £65 and it is something you can do yourself then it negates paying £700 for the diagnosis and more than likely you can repair it yourself. Let us know how you get on with it- Last week
- Led headlight
Nissan's local dealer sent me a email with the repair cost , they also found one of the springs had cracked and needed repairing which turned the cost up to £1294 luckily the warranty covers the cost- Nissan Note service reset
Hi, thanks for letting me join the group. I have a 2010 Nissan note and I am having problems resetting the oil service light. When I try to reset as per the manual nothing happens. The spanner symbol is flashing and the zero as soon as the ignition is switched on. Also the when pushing the right hand trip button the clock will not adjust.- Service on Maidstone
Hi Can anyone recommend a reliable garage in Maidstone to service my 2013 Qashqai? I just moved there so need some guidance. Thanks in advance.- Software issue re auto gearbox
Sometimes when I accelerate from a slow speed eg approaching a roundabout - there is a lack of response unless I rapidly tap the accelerator and and then get a response. Dealer says issue is relearn gearbox - a software download from Nissan headquarters - that in my case is not working. Has anyone else had a similar issue and was it resolved?- 2015 pulsar - android screen and SWC function
Slight correction , the basic harness has only 1 whit plug and no canbus . They all “work” but none allow SWC !! The “SWC APP” built into the head unit does not recognise the buttons being pressed !!- Hi from ireland
- Intermittent Loss of Clutch Pedal 2016 370z
Hello... I have a 2014 Nissan 370z with only 6,100 miles that has suddenly developed an intermittent clutch issue. I lose cluth pedal and goes to floor occasionally, and the car can sit for a few days, and the problem goes away. Clutch and transmission will then operate perfectly for a week or two, and then the loss of pedal issue appears again. Any help would be greatly appreciated. Chuck- Navara 2021
- Hello From italy
Good day to all you Jukie owners. My Nissan Juke doesn’t seem very fuel efficient for a small car. I mainly do short trips and I’m only getting low 30s mpg. It’s a 1.2 DIG-T petrol. I was expecting better but maybe that’s just unrealistic. Is this normal for the Nissan Juke or should I be checking things like tyre pressures, air filter or spark plugs? Curious what other owners actually get day to day. Cheers Guys- Strange engine noise on Nissan Qashqai e-Power when stationary
Fuel efficiency (of whatever source - petrol, diesel, electric, hydrogen, etc) is quite popular on many forums at the moment. Mainly because of the fact that people bought a vehicle based on the manufacturer's advertised efficiency which has been way short of what is actually achieving in the real world. Have a check on forums such as ToyotaOwnersClub.com and there is a huge discussion which debates the best methods of driving with electric or hybrid vehicles. Good luck and Merry Christmas to you also! - P0356 error code
