Hi all. I have a 2017 xtrail 1600 and last week a message came up on the dash. Oil change 100 miles. So no problem carried on driving and a new message said auto stop start problem not working and the power started to drop of when trying to accelerate. I looked on Internet to try and find problem with no luck. But then I found a thread about if your nissan is coming up for an oil change it can make the start stop not work and turn on the engine light yellow or red. When I purchased the car from sparshatts at millbrook Road Southampton they renewed oil and filter but didn't reset service intefall so the cpu must has said gone over service period and flashed up stop start problem. The fix was to go into maintenance menu and reset the oil service data to reset. After doing this the car is fine. None of this is in the hand book. Nissan should be more honest about how the software works on their cars to Joe public. I hope this helps.
Nissan Roadside Assistance Cover
First thoughts....do you rest your foot on the clutch pedal at all? If so, then you have worn the release bearing and this is the reason for the sound. As long as it doesn't get any worse then it should still be good for a while
I've got the same issue. The dealer said the car is designed that way. - Last week
2005 Micra and unable to open drivers door from the inside, managed to access lock all cables attached and when you pull the inside cable the lock does not release, the outside door handle works ok so guessing internal fault with mechanism itself. now the challenge how to get the mechanism out, window mechanism is in the way and I cannot fathom out how to move it out of the way, any advice welcome thanks
Hi everyone, looking for some help and advice! i have a 2011 Nissan Qashqai 1.5 I have noticed there is a ‘whistling’ noise coming from engine area, it seems to start once the engine warms up and Ive been driving a while, I then noticed when the clutch is engaged the noise stops … foot off clutch it starts again, but the whistle itself can be intermittent. I have been told it is the ‘throw out bearing’ but upon doing some research it could be something else and something alot less costly… has anyone had this or can advise?? I have limited funds and I am wondering if I should question mechanic and maybe try other options first. any help would be greatly appreciated.
Hi, I have recently brought nissan leaf 2016 model. Car was working fine if its showing 73 miles range then it was giving 73 miles only thing nissan connect ev app was not working. So I was trying factory reset setting in car and I think I selected wrong option from internet in system diagnose menu(Using MAP,MAP,MAP,POWER,POWER,MAP) and looks like it deleted factory configuration data. After this action My rear camera and 360 camera stopped working and I am no longer able to see Nissan connect in car head unit. But my main issue is that this affected my car driving range. Yesterday I did full charge ma car it was showinh 83miles but it only gave 53miles so looks like ECU data deleted thats why car is not giving acurate miles. Does anyone know what that initialise factory data means? (Screenshot attached) Do my car required ECU reprogramming? Does anyone has any solution which I can try or only its something Nissan dealer needs to do? I have called Nissan dealer and they asking initial £250 for diagnose and then they will let me know reset of repair cost. Any help is much appreciated IMG_4630.HEIC IMG_4631 copy.heic
https://nissparts.net/ send me your list and vin code of your car
Hi, has anyone had this problem. When I first start my Murano, weather it is hot outside or freezing cold its always the same. The car will start then cut out after a few seconds, it does this anywhere up to 5 times and then its absolutely fine for the rest of the drive. I have had the fuel filter and the glow plugs replaced and had pdf treatment put in the tank. I have run the car at 3500 revs for 10 miles, but none of these things have sorted the problem.
Although I don't have a Qashqai ePower i's say the response you've had is unhelpful at the least and possible baloney. Does the 12V socket (fag lighter as used to be)stay live when the car if off? It might stay live for a minute or 2 as the car shuts down fully, but if after that it completely switches off then there's no way you'll drain the battery. if the 12v socket remains live then just get in the habit of removing the dash cam plug from the 12v when you leave the car. TBH it would take a few days to drain the car battery completely, but it's worth getting into the habit rather than finding out how long it actually takes - the hard way! BTW I fitted an inexpensive Amazon dash-cam to my new-to-me 2015 T32 X-Trail just last week - and today there's a 20% voucher AND 10% promo - so I've just bought another one for my youngest lad - he's 17 next Thursday and will be taking to the road in a 2009 K12 Micra. A dash-cam has just been added to his presents !
Bună ziua.Stie cineva la motorul de Nissan qashqai 1.7 dci din 2019,distribuția este pe lanț sau pe curea.Și dacă ma puteti ajuta cu alta nelămurire, masina a stat mai mult timp nepornita iar acum la pornire apare in bord mesajul fault sistem start stop,problema este de la bateria care este descarcata sau este vreo problema la instalatia electrica?Multumesc!
Hello everyone, My juke is just about 30,000 mile, touch scream/radio keep turning off and on. Having soo much noise from engine. Have use care for about 1 year. Can anyone advise what could possibly be wrong with by care. Love my care so much. Thanks
I found a solution, for whomever has a similar issue. I cleared the DTCs from the SRS system but the light staid on, then I noticed there was an airbag-related DTC in the body computer and clearing that worked
I had simular checks on my dash that they didnt make any sense. antipolution filter fil assistant, check injection etc. the car was working fine. The problem finally was the battery
problem starting sometimes
giorgos anagnostakis replied to GayEddie's topic in Nissan NV200 / NV300 Forum
it could be the battery. -
greetings from Greece! I have bought my car at 2017. From the beginning and all these years i have a problem that the local nissan cannot fix. even though they have changed eveything again and again. When i travel on the high way for a long time, when i press the clutch (from 6th to 5th ) it feels "heavy". after i press it from 5th to 4th it gets normal again. (there is no problem with the gears) when i drive in the city or small distances that requires pressing the clutch often everythings works fine. The only problem is on the long distances when the time comes to press the clutch its seems to loose the hydraulic pressure. It gets really problematic when you travel for 5 hours or so.. Is there noticed the same thing? I have changed all these years almost everything that relates with it. It seems that the fluids are loosing their power from heat. (heat from engine?)
Had my qashqai 2.0 dci about 4 years now, when working on engine some while back I took it for a run without engine cover and air pipes on, amidatly noticed fuel consumption dropped, now getting 10 mpg more without air pipes.
Back box for Primera SVE CVT 05 Reg
Trevor replied to Jeff F's topic in General Nissan Owners Lounge
You can find suppliers on eBay for stainless steel custom exhausts much better than original and not too expensive either Usually drive there and wait while they build you a system (or part system) -
thank you. found one from a breaker.
Hi, The digital part of the speedo is regularly not displaying the correct information as you can see from pictures. Has anyone had this issue and how was it rectified?
Hi, My Navara 2013 D40 is on its second set of glow plugs and second relay in a year but every so often it goes into fault and puts engine management light on which will eventually reset itself. Two separate garages have never resolved this problem. Has anyone on here had same problem and how did you resolve it?
